nicolapastena
thanks after some other modification it seems to have solved thanks
Right. .error is the following error when sending the cam to the program.me does it when I open any part
first do not open the files directly from the file butboys place the error that appears when I open directly any solidwrk file (compare once it disappears, when restarting the pc reappear again... )
Still? !... returning to the lazy, in the video you posted me I realized how to go to change the cut peò to me would serve full the pinion as you can do? in the second part of the video in practice go to eliminate the error that appears to me by doing the extrusion, but this operation is lawful? Can you give me trouble?
If you send me a video that explains how to do you I would be really grateful
