help setting teamcenter
  • Thread starter Thread starter ceschi1959
ceschi1959
I have a small problem, which I don't know about teamcenter I don't know how to set up a new drafting suffix. comes out in fact man1... man2 and not drv as I would like.
Does anyone know what to set up to make sure that the suffix I want is put?
it is made by nx customer defaults.
go to "teamcenter integration for nx" - "general" - "file new" and in the field "automatic names for new parts" put the name you want.
Bye!
Bye!
Thanks stefano of the answer.
Unfortunately it seems that it is not due to this approach which, in particular, is set on dwg. the suffix that appears, instead, is man.
Do you have any other ideas?
Um, let's get this straight. . .
a couple of questions: is the approach in master model? that is within the item-revision there is a dateset ugmaster (model) and from this you want to create a dateset ugpart (table) with the same name and suffix for example -dwg1, -dwg2 etc.?
or is the problem as the "sheet" is mentioned within the nx file?
In any case, the option I indicated before presupposes that you, after changing the customer defaults, exit nx and also from teamcenter (also closing the windows dos "taoimr" and then rebooting them.
But I don't have the chance to do tests (I'm not from that client). I'll tell you what this is about, and then I'll tell you what.
thanks 1000 for availability.
