help solid edge 20 - refused academic license code
  • Thread starter Thread starter SandMan84
SandMan84
Hello everyone, it is my first post here; I tried to look for a topic that could help me, but I found nothing.
I own an academic license distributed by the professor of the course and I had already entered when I first installed if 20; because of a problem with xp, I had to format the laptop and then re-install everything.
It's already happened to have to reinstall if 20 after formatting the notebook, but today after reinstalling if 20, when I go to enter the license code in my possession, it gives me a screen saying:
"The key inserted for solid edge academic is not valid for this machine. contact the unigraphics solutions or system administrator to receive the right key. "That license code worked three times over a year, but now it gives me that mistake.
How can I solve this? I'm a little anxious, because I have to change and complete the project for the exam... help! !
How do you mean the selicense.dat file?
if you look that if you reform your pc to reinstall windows, the serial number of the hard disk automatically changes, so being the licenses of if tied
you have to regenerate it.
so it works for commercial licenses, but I assume it is the same thing for academics as well.
What do you mean three times?
that you used the program 3 times or that you formatted for 3 times?
I don't know how academic works, I can't use it;)
You should ask for a taste.
no I mean the 12-digit code to be entered on the license utility to enter such codes (start->solid edge 20->licensing->license utiliy-> license keys).
I'm sorry, I might have been wrong.
I mean I installed if 20 already 3 times, because for one reason or another I had to format the notebook for 2 times.
the first two times, the code (it is a 12-digit code that allows use for academic purposes, given to me by the professor) has been accepted without problems, this time no and I do not understand why!
I don't know the academic licenses, but with the normal ones the license file is the selicense.dat file.
If you still have a copy, open it with wordpad and read the hard disk code on which it is calculated, then change the laptop hard disk code to make it consistent.
otherwise you need a new code.
Bye.
