help update
  • Thread starter Thread starter avalon3d
I at the moment, when I work on assiemi with links or disable partial loading or active "load interpart data all levels". This makes no mistake. the problem is when you have to take into mado something done by others, where for example a save as of a file that is a parent of a link keeping the file with the link partially loaded. practically the file with the link remains tied to the old version of the father ... how many years of purgatory made me earn this problem!
As for what you say, one of the nx 8 improvements is exactly this.
I should look for the discussion on another forum, although it is not easy to find it.
I can do tests if you tell me the steps to perform to reproduce the situation.
I'm still sure what I said and read.
saving with file name with wave ties with the options described and nx 8 should not generate this failure to update references.
no because it was made native with nx8, and with those settings it comes out like this.
attached 'clean' installation image: the reference model also loads the surfaces, so you also changed the settings on your default customer if you charge only solids.
all your files have only one solid?
right, everyone has their own working method and according to its needs goes to customize both default custumers or templates. Some things don't find them either in the help or in the cast but you find them on you without even realizing it. Maybe if you've experienced it, try to protect yourself first.
then as you see, model is a reference set generated by default in the parts.
we produce automatic machines and make 3 product types:
1) sheet = only a solid
2) Mechanical objects = only a solid
3) Printed parts = Delect construction surfaces from reference set model and hinges (not use layers)
returning to the address of the loading options, if I have understood you argue that by activating "smart lightweight data" and loading with "partial load" the system automatically solves (or at least does not create) the usual problems of untouched links?
If it's true, we're getting green because I have to pay you a drink! :wink:
but it seems too beautiful... I bet I got it wrong! I at the moment, when I work on assiemi with links or disable partial loading or active "load interpart data all levels". This makes no mistake. the problem is when you have to take into mado something done by others, where for example a save as of a file that is a parent of a link keeping the file with the link partially loaded. practically the file with the link remains tied to the old version of the father ... how many years of purgatory made me earn this problem!
I confirm what is stated, as tested.
with the three set options and a refile you have improved loading performance and an update of links in case of save as of fathers.
Great! Now I'm just curious, as soon as I have a moment of real time and let you know!
