Good morning to all, I ask for advice to be able to perform this piece in rhino 3d for a university project... thank you all for the collaboration! ! ! ! !
france
Nice!
Step 1: What do you need to make the object model? renderings? of what quality? have a model "from bookshelf" with footprints and aesthetics to the good to insert in larger projects? is the skin enough or is it useful to describe the inside? What do you need? Do you have to build something (equipments, molds? )
point 2: the object already exists and you have to make a copy of it or you have to design a similar object?
depending on the reposts at the first two points you can choose the working stategy... otherwise you can not suggest anything more specific than to turn on rhino and start tracking lines and surfaces. . .
I just have to make a "inventing" reproduction of plausible dimensions. ..I just need to realize the aesthetic model and, in case, specify the assembly between the various parts! I was looking for suggestions to make the object...for surfaces? or start from lines and then create the surface?
