mdbosca
but have you noticed that the hexagonal heads of all types of screws and dice are wrong?
example:
screw m10 size 16mm instead should be 17mm (just for the 17 key)
screw m12 size 18mm instead should be 19mm
screw m14 size 21mm instead should be 22mm
I know it would be a lazy shop, but for me it is important to see swallows and/or interference.
do you know the file name to go to edit? I can't find anything. .
example:
