Quoque69
hello to all
premise, as you all know when you use the unmounted connection and you can also create the hole for the passage of the screw.
I created and published in the center contents the hexagonal thread inserts that we use habitually so as to use them with the connection bolted but I can not run the hexagonal hole if it is possible? would be the best to be able to create the asola too
thanks to all in advance
