snake779
Good morning.
as from title I would need to know if there is a way to speed up part lists with bubbles without making explosions.
I'll explain. I have a set that I put on the table with isometric/trimetric view, from this view pull down my distinct materials and do the automatic bubble. Of course I can only bubble what is visible, if I have a hidden detail does not make me bubble it. Is there a command that can generate a decomposed section to see the hidden elements?
or if not a decomposed section, something like that?
ps. I do a note. many times when I do auto bubble, even some items that are clearly visible, are not branded and I have to do it manually. Is there an explanation for this?
thanks in advance
thanks in advance
