hidden details bubble
  • Thread starter Thread starter snake779
snake779
Good morning.
as from title I would need to know if there is a way to speed up part lists with bubbles without making explosions.
I'll explain. I have a set that I put on the table with isometric/trimetric view, from this view pull down my distinct materials and do the automatic bubble. Of course I can only bubble what is visible, if I have a hidden detail does not make me bubble it. Is there a command that can generate a decomposed section to see the hidden elements?
or if not a decomposed section, something like that?
ps. I do a note. many times when I do auto bubble, even some items that are clearly visible, are not branded and I have to do it manually. Is there an explanation for this?
thanks in advance
you can do a normal section and set it as isometric
you can create a model configuration and cut concretely what interests you
-I did not want to use configurations because I already use them for other purposes
- How do I do a normal section and set it as an isometric?
Right-click on the view in section - isometric section view
Otherwise you blow.
-ok found view in isometric section...thanks
-I wanted to avoid making explosive views every time, so and more immediate. I don't need it as a mounting scheme, but just to get to know where that detail is.
why does not occasionally bubble some pieces that you see clearly is normal or only happens to me? ?
can it be that it is a part with quantity greater than one and that the bubble is inserted on a position other than what you expect?
Good morning.
I connect to the discussion to ask more or less the same question to today that you never know that some update we have changed something.
I have a general set of a machine and I make the table with the visible dotted lines (so all details). when I do bubble I only bubble the visible external components. is there a way to brand all the components I have in separate, so also those that you see but dotted?
thanks in advance
Good morning.
thanks in advance
you obviously talk about automatic bubble, had this following the legislation that indicates that you do not quote the hidden elements. therefore rightly solidworks does not apply bubbles on hidden elements (because of this we speak, not of visible dotted lines).
that already the automatic bubble puts the balls where he wants, if missing some put them by hand.
