hidden lines covered
  • Thread starter Thread starter MaiMollare
MaiMollare
Good morning
I set views with transparency (hidden) but on the table, although the stretch is thinner, I can't see the hidden lines covered. I went to the properties but I can't locate the option to see the dotted lines. you know tell me please, use I create parametric 6. Thank you.
Hi, it's correct.
Hidden lines are displayed at video with a "great" color, then when you print the design they are dotted.
instead if you want to see them covered even at video, then you have to check on the config if there are any options that allow you to do this. .
