hide cartridge
  • Thread starter Thread starter dicifa
dicifa
Good day to all,
I have a question to ask you: in the templates I have a single table with inside dozens of different companies like surely all of you....my question is: if I create an idw and send the design to the customer, how do I hide or delete in an automatic or fast way the rest of the carts with the respective names of the companies?
thanks to all
Good day to all,
thanks to all
but wouldn't it be worth making a template for each customer and its table?
I had thought about it, but if I have to make a change in "editor styles" I have to do it on every single table and I would throw away a lot of time... .
i had thought about it, but if i have to make a change in "editor styles" i have to do it on every single table and i would throw away a lot of time... .
you have to use styles from bookshelf, now use styles in "local".
try to take a look qui.
...I tried to look but not or understood too well. I have to look calmer and maybe without the heat that kills me!!! ! ! ! ! ! ! !
put each client on a different layer? active only what you want and styles are the same
