hide elements from a single view on the table and configuration
  • Thread starter Thread starter leleallariscossa
leleallariscossa
Good morning.
is it possible to hide individual elements in one view of the design without creating a family table and then 'save' another prt? I have to hide the side walls of a box to make the issometric, but in the various commands I found only the possibility to hide an element for all the views of the design.. for now I solved by making the family table and setting the desired view associated with the model of the family table.. .
this process also use it to make a configuration (for example to show the door of this open box)
Are there any other roads?
In addition to the method that uses fts, you can use the simplified representations, or more simply, in the table setting, > turn off display, and click the component not to display.
there is the option to hide/make "fantasm", every single component, in every single view or in all, without creating family table, simplified representations (eye that bom faithfully follow the simplified representations).
