hide single drop down menu
  • Thread starter Thread starter rikk
rikk
hello to all and good day.
as from object, I ask if you can hide a single autocad drop-down menu. for example the menu quotatura or edita.
thank you in advance to anyone who will help me. :smile:
command to which and from there delete the drop-down menu (if you want to delete it. . ).
curiosity: but why do you want to eliminate it?
Thank you for your answer,
but I didn't want to eliminate them. Just hide them.
because now I find myself with the menus on two lines (I have 20 drop down menus) and half do not use them. so to optimize the work area I wanted to recover that little space.
Do you understand? :biggrin:
But you're talking about ribbon bars, then?
in any case you manage everything always through the customization of the user interface.
I didn't understand how you got it, but you could create a new tab where you can group only those you use less.
bè in this case delete them from the display in your profile, always from which.
but not completely eliminating them.
