hide solids in idw
  • Thread starter Thread starter Tarkus
Tarkus
Hello, people.
I'm starting to kick the bolas out right now.
I have an ipt file with more solid.
when I put it on the table, I would like to hide one of the solids, but even if in ipt I put the solid as not visible, in idw you see, yet, if I release the knot in the browser in the idw, I see the processing that created the solid to hide as hidden...:confused:
Any ideas? :smile:
in idw selection filters select "body priority" - select the solid -> button dx -> visibility
But you say the green cube command? There's only prioritity edge, work and part; always there I can go to "custom filters" and I can choose "body" but I don't get anything, when I click with the right I find only the choice between "propriety" and "selected as edges".
Are they off the road? :confused:
Do you have body priority?? I have 2013, but I don't think it's a novelty of the new wreck
on 2013 there is and it works as you say, only I don't want to use it until I've put in place vba material colors and other customizations. . .
I add that it's a good news that makes me reevaluate a little ' 2013....I hadn't noticed it in the news...
I select simply "priority part" in the idw selection filters, then select the part that interests me to hide and with the dx key, click on "visibility" as said wedges and the game is done. but I have always done so in previous versions.
cmq as heavy graphics, it seems to me that 2013 is exactly like 2012: a penalty!:biggrin:
Yes, but priority part works when you have a set at the table and you're choosing a part to hide... I have only one part on the table with more solids and I want to hide one or more solids, not the whole part. .
