hide together while changing the part
  • Thread starter Thread starter SE-Bologna
SE-Bologna
hello to all, as from object I can not hide the axieme (which is semi-transparent during the change) while I change a part.
In addition, if I select a wireframe view (so not shaded) I only have some parts visible.
thanks to all in advance for the help
thanks stefano, for the edges I solve but in fact (I am explained little) I need to see the axieme but also to be able to turn it off or turn on "at flight", not as system setting.
you can try with the solution "isola", in a set select the or components click dx and choose island, to remove go from broswer select a key component dx and cancel insulation
