high yield as wall nn possible
  • Thread starter Thread starter archguida
archguida
hi to all l a problem cn the ribs, I have a profile to the high and wide 10 cm , I have created a line for a ribbed as high as the wall or 10 cm, to the execution I receive error, instead if the line of the ribbed and lower of the wall even of very little the operation is executed, wrong something or nn can be done? Thank you.
in mechanics we talk of mm and not cm.
very little is not a valueable parameter, especially if you reason in centimeters; 1 tenth of the lower millimeter makes you trouble?
solidworks specifies that error you get, does not say error and just; Perhaps it would be useful also to us to know
attach images or even better the file?
Thanks for the answer, if the line tilted and high as the vertical wall you receive error, if it drops even a couple of tenths can do it, but it seems strange that there is such a problem in such a program, now unfortunately I can post pictures if I can tonight, thanks
