Marvel
Hello everyone, I should make a showcase and at the moment I can not, together, make the door and zipper move correctly (then they will be 2).
I managed to set the movement of the door with the limit angle function and to make it close and open correctly with the angle I need, but the hinge remains me still where it is, that is it does not move agreeably to the door (it does not move "hinge" in short).
The hinge is also a separate set (loaded by grabcad) and moves correctly in its set (which is then reported in the "vetrina" axieme), but when I try to move it "hinge" in the axieme "vetrina" I get only a translation in space.
I also tried to search the network for some tutorials about it but I found nothing about it.
Can anyone give me directions? Thank you!
Bye!
Mar
Bye!
Mar
