hold in a dynamic block
  • Thread starter Thread starter caster79
caster79
hi to everyone, the question is very simple and I would first try it directly but I can't resist waiting Monday!
Let's imagine creating a simple rectangle, within this rectangle I have a dash, assign the linear parameter and the iron action to change one side. is it possible to make sure that the dash is adapted to the changes made?
if I don't remember badly, making local changes to a traditional block, always with the iron command, the deduction does not follow the changes, this at least with the version of autocad that I use that is 2008.
great thanks!adesso that I think about it can be that depends on the fact that I inserted the dash inside an area and not for the objects that delimite the area?
because in reality by rectangle I do not mean the polylinea created by the rectangle command, but of the lines that form a rectangle, perhaps this is why the tracting did not adapt after the change
