Stefano_68
Good evening to all,
This is the problem that I cannot solve:
- design a flange (extruded circle)
- I create a sketch, design a point and I carry out a circular series
- I use the hole command that runs a hole for each point.
- I create a new side file and inside it comes the flange
[Bleep] now I don't know how to create holes so that if I change the diameter or series in part 1 you update part 2.
thanks for the attention
if you can explain the step-by-step procedure
