gil
I would like to ask you some explanations about metal structures. how much the holes are designed must be taken into account a standard which, depending on which the distance of the hole from the edge of the metal plate must be >= to 1.5 diameters (or >2diameters at the center of the hole).
Now we make this hypothesis, in a base plate that will have to lean on the foundation in ca. we hypothesize that the plate will be anchored by threaded bar diameter 20 mm. the hole of the plate must be equal to: 20mm (throat bar)+3mm (zinc and game) + 20mm (maggioration for any adjustments of the position)= 43 mm approximately.
it follows that the distance of the edge of the hole from the plate must be about 45 mm, this often and willingly implies very large plates. more than normally designed, due to the increase of the hole due to the "game" which allows for possible corrections of the position of the plate compared to the blade. the domada is:
Is it fair greater the plate or does the norm contain excitations for the basic plates that I am not aware of?I ask you the question because I rarely see this prescription in buildings.
