RiccDS
Hello, they laugh here. I've been stuck on something for weeks. I am attempting to make pairs of polypropylene sheets (1mm and 0.5mm thick). I am using a home oven(I know I know) from the large size. in practice we buy these sheets between two 1.5cm aluminum plates. to give pressure use four tightened screws with dynamometer key and a 5mm aluminum plate(I will replace soon with steel) making as a spring. The pressure seems to be fine. the problem is that from the observed result I think there is a seemingly uneven temperature field so that in the center of the coupling we observe characteristic undulations and without shadow of doubt ugly. I think it is very probable that the center of the plate is exceeded the temperature of 165-170°c and in practice the slag pp. What I don't want. I attach a photo of the oven (ventilated, upper and lower heating); the plates for now rest almost on the 3 lower resistances, on those steel sleighs specially built.
Do you have any idea how I could uniform the temperature in the plates without raising them? I think this disuniformity is due to the closeness to resistors, which go to much higher temperature than that set. I thought I'd use a copper plate to put under but I don't know if that's enough.
