home
  • Thread starter Thread starter driver
driver
Hello, everyone.
I must realize a tubular rod that ends with a flat part (for a subsequent fixing), obtained "mozzando" at 3/4 the section of the rod. I can't make a good connection between the flat and the spherical part. Is there any command?
I'd say you should be clearer.
I didn't realize you had to do it!
Do you mind? ? ? ?
use loft protusion.
basically you draw the sections of your tube (compared to the axis of the tube) and then extrude with the loft command.
with the loft gives me an intersection error of geometry with itself. The guide says you can use the blue surf and I get perfect. Can you go?
But there is a problem.
the extrusion of the flat part is ok. However, after doing the blue surf for the "conic" part (which connects flat and tubular part), I should also protrude that area there (which is a conical trunk crown). I tried to use loft extrusion but it makes me mistake. How can I do that?
Thank you very much.
