home
  • Thread starter Thread starter iron72
iron72
Good morning.
are at the beginning of creating condos.
I created two tubes with the extruded comado, then I put them together at a certain distance then I gave them a route automatically. here all right only that when I have to insert a pipe style, a window appears to me with the following message:
"The style of pipes and current pipes uses content currently not available in the contained center. check the content center settings or change the style. "
I'm putting my party together here.
As the message tells you, you didn't define that piping style. look on the guide there is a valid explanation about pipes, links to place on custom ducts etc. also searches within the forum that has already been discussed and there are those who made custom lalibreria and explained the problems.
