home
  • Thread starter Thread starter Mario_Comea
Mario_Comea
Immagine.webphello to all, as you can see from the image I attached to you, I must create a soldering between the particular in red and the gray one near those 2 bevels to 45° that I did (as if it were a kind of cyanphrine).
How can I create the welding cord?(without drawing the cord sketch and making the revolution)
I wait for you and have a good evening
I propose this solution:
extrusion of one of the two tilted faces in the direction of the other with the until extended option as shown in figure.
thanks baskets, but wanting to use a welding command, what would you recommend? Sincerely, I would like to avoid building my welding.
Moreover, I do not know if it could be useful as information, but I am working in assembly environment. changes something for what I want to do?
I do not know the welding module and its commands because I do not possess it, in these cases you do courses online with siemens, are very profitable and cost little.
Hello there.
online courses are profitable for those who cannot use nx, but are dated. files of examples still built with pads and pokets when explaining how to use sketches. rendering courses, welded fems are of a simplicity that does not cover any real case. are more fruitful books made of those who grounded nx for years or courses made by those who actually use it.
the command to use is groove, but if you do not know how to use it, then it will be hard to get there right away. the surfaces to be selected are the two cylindrical ones and you must set the bevels 'already prepared'.
