home
  • Thread starter Thread starter stefano apostoli
stefano apostoli
Good morning.
I'm new and I've installed inventor recently. How do I change this flange?
I should take the 49 to 52 odds, but it's all over. to make the arched part I used the spline.
if I put the bonds don't accept them.
help... .
also how do I to unify the splines between them so that the flange is empty to the unternate and full externally?
You miss 17 odds to define that figure, of course everything disappears.
I would also like to understand why you use the spline for the arched part, the spline is the line less easily governable and impossible to reproduce with a traditional machine.
said this, for the problem of extruding only the external part, just define " construction " the two horizontal lines, the splines are not to be combined.
It doesn't extrude me the central part. . .
How do I get this result?
