Esselle
I would need some inspiration for the design of this plot with inv 2010. the hopper must be made of 4 separate walls and then assembled by welding (except for the lower "rentangle" part which can also be soldered later and should not necessarily be a unique body immediately with the main walls).
the welding between the walls should be made all outside, thus combining the internal edges.
100 mm horizontal fins serve to support it on a frame. is it appropriate to create a hopper with the new function of the 2010 version and then to obtain from this 4 parts derived from reassemble then in a set?
How do you advise me to proceed? other ideas?
Thank you so much!
Thank you so much!
