hopper
  • Thread starter Thread starter blubossa
blubossa
I'm making a hopper but I can't make the folds....who gives me a tip?
I attach files.
bb
Hello blubossa,
In my opinion, in your model there are no corner drains to be able to develop the sheet.
I have seen that your model is made with the wf5; I use I create but I still attached 2 file steps.
in the first you can see your model with the added waste while in the second you will find directly development.
I hope I helped you.
:smile:
Hello Fabrizio67,
You could attach the file to me even in creo version.... at home I can open it. . .
bb
Hello, fabrizio,
I saw the attached files....in practice you prepare first the unload and then convert to sheet, it seems that it works properly.
but is this the exact method?
bb
Hello blubossa,
:smile:
Hello, fabrizio,
bb
[Bleep]
Hello blubossa,
without waste, the resulting geometry cannot be developed; all should be clearer seeing the piece completely open.
Given that the result can be achieved by following various paths, I have no presumption to tell you that this is the best, indeed...
when you want to transform in particular sheet a solid model, you normally use the feature conversion to define the discharges; I had no way to do many tests (even because with creo I have not yet taken the dexterity I had with the wildfire) and therefore opted for a more homemade solution, but certainly effective.
Now it is clear to me why of your choice... thank you.
By the way, how are you with the creo version?
bb
How am I with creo?? ?
to use an euphemism I could tell you that I feel like a fish of water...:eek:
...I miss most of the time to understand where the devil repositioned the various commands...:confused:
...I will need a few days to update...:mixed:
...consider that when the ptc abandoned the original interface to pass to that of the wildfire in comparison it was a walk.:rolleyes:
