how are files saved in old version?
  • Thread starter Thread starter dicifa
dicifa
Come on, girl.
Can you tell me how the old version files are saved? what I want to know is every one that creates a new file.....
every time you save, it's not like autocad.
ok.... but you don't know how much it creates a new file in old version? ....I ask because I did a particular, the next day was modified and in old version I couldn't find the file of the day before.....
In fact, I have a doubt. I remembered (and old old folders confirm it to me) that at each rescue a file was created part1 -> part1.0001, part2.0002 so on. now I tried but instead of adding files to the folder only keeps the most updated version (no part1.0001 but only part2.0002). the help (salvation, file versions) seems to confirm the first mode of operation, but... I looked in the settings but I didn't find anything, I lost it or confirm that there are no settings on it? especially, now you only keep a version or keep them all?
seventeen: help save > file versions describes what happens to the rescue (inv.2011)
Bye!
the variable is located in the project editor (at the end) in the line "options" -> previous versions to be saved. Write the number of previous versions to hold, or if you write-1 keeps them all.
perfect!!! I really needed this.... attached to agni salvage creates a new file. :4406:
Now the only problem could be that it creates a thousand files... .
If I insert "0" it doesn't make me any version but it creates the "old version" folder. Is it possible to tell him not to create a folder? :biggrin:
As I see it, I wouldn't give up old files, they can be useful for rethinking.
Maybe at the end of the night you do a purge and delete folders and files...
