how can i edit a .mmf files for hypermill?
  • Thread starter Thread starter ixx
ixx
Hello, girl.
someone can tell me how I can do (with which software) to change the model of my machine (it is a .mmf file) to use it in hyperview hypermill?(the file is already working but now they want to add in the machine an equipment and I wanted to insert it in the cinematics, to be able to make collision control in hyperview hypermill).
thanks:confused:
Bye.
instead of changing the machine in the *.mmf file, you could activate the clamp function in the machining list.
this function allows you to select new control surfaces that you will find in the hyperview on which not to go to collide (e.g. special brackets) .
by default, the clamp function is disabled.
to activate it you should contact openmind assistance.
Bye-bye.
Thanks for the answer, but the problem is precisely to control the collisions of the machine, which has been equipped with another equipment that is not an equipment, it is part of the kinematics of the machine.
I need to see if this new equipment doesn't go banging on machine pieces.
if not mistaken, the software that serves to change the model of the machine ( .mmf file) is called "machine builder" .
I think it is introvabile and not sold (to customers) by the openmind itself.
