how do i develop this...
  • Thread starter Thread starter Eliuz
Eliuz
How do I develop this...
I'm going crazy: eek:: eek:: eek:
What version of this? is it also in sheetmetal or in part?
from the image would seem correct, that is made in sheetmetal but I would like to remove myself
the doubt.
on the st2 I know that you can develop this type of profiles, possibly post the file that we look at.
I have a v20 made of sheet metal but the problem is that on the round part I should have a connection point and not two ... how do I change it? I show you an image of how it should be
the problem is not only on this particular but also on others I have to understand how to define the folds for radiating from point to circle and not from circle to circle. .
in the circular sketch you must add to the ends 2 lines, which later (after making the loft flange) you will have to delete with a dig.
I don't know if I understand well but so I don't get any results
did you understand what I wrote to you, did you try to do the same on the other side? (with st2 it worked, for knowledge I put the material on the outside).
I confirm with the st2 works, but from what I remember about the presentation of the st2 this type of development seemed precisely an implementation that in previous versions was not there.
