how do i make orsogril grills?
mikelegnr
Hello everyone, I modeled a project in which there are pavements made up of orsogril-type metal grid panels.image.webpSince, if I had modeled the material in question, the file would be too heavy, I created plans on which to apply a texture. the three-dimensionality I wanted to get it with the displacement. Can you help me find a good texture or material and tell me what values set x get a good result? thanks in advance
ps: use 3ds and vray
You create a map.
take a photo in the plant of a grilled and give it as a texture.
transforms the same photo in black-black where the holes and whites will be the transverses, the saving with the name of the texture followed by bump (but only for your memory, you can call it as you want) and in the new material you check the photo of the grilled as texture and the photo in black-black as bump.
that I remember in 3dmax there were just some grilled materials give a look at how they are made.
I tried but you do not read the three-dimensionality, and then if I put a photo as a texture I do not see what really is under the grill
in the material editor you can insert a map of cutout. Regardless of bumping, the cutout is the map that allows you to crop the material. the black of the cutout map represents the hole.
the cutout map is reversed. If you put it 100% you will see white as solid and black as hole.
if you put it to 50% the "solid" part will be semi-transparent. Do your evidence...
the tridimensionality you are looking for will never have it with a map. If that's what you want, you need to shape the panel.
