MauroTC
Hello everyone, I have a doubt about how much can affect the heaviness of a part within a set (and an idw) depending on how many times it is repeated.
I have received an ipt part, very complex (full of curved parts and radiances) obtained, from what I can see, from a step, that therefore I can not change if not doing it (then it is complicated).
such ipt “weight” 7213 kb.
what would interest me to understand (if someone has such knowledge) is what can affect the heaviness of this file depending on how many occasions they insert it, in a set and in the relative idw table of this together.
I'll explain better.
if I load one of these ipts in a set or I load one hundred (which are those that I am managing) the iam is weighed 100 times or manage one is how to handle 100 (because it is the same object with several occasions)? or is it a halfway between the two?
(of course at the kb level of the axieme there is no such increase, but the axieme is only a manager of constraints and little more...)
and for the idw is worth the same?
to understand whether it's worth putting your hands on us and giving it back, simplified, or not...
thanks in advance!
thanks in advance!
