how to change unreasonable revit
  • Thread starter Thread starter CAROLINA
CAROLINA
someone knows how I can access the revit template to change it for example I would like to change the layers colors definitively so that I can export the projects in cad and always have the same layer setting for all projects .
thank you dear
thank you and a thousand for the advice now everything ok.
but if in the load template also families and settings I usually use for the projects then I remain in memory for later projects.....
Hello, thank you
