how to create "block"?
  • Thread starter Thread starter genale
hi I'm learning rhino these days.. how can I create 3d blocks like in autocad?
using rhino blocks is a two-part operation.
1) first you select all 3d/2d objects (...but also external files) that will constitute the block with the obvious command _block
2) then, to insert multiple times the block in the document, you use the command _insert
I suggest you do some tests and read rhino's help which is quite clear on this command:
Thank you... I couldn't find the command!! It seemed trivial! ! !
curious what area of the Veneto are you?
eheheh for the series ...too simple because it is so:biggrin:
province of treviso... but closer to low
