Marco-92
Good morning.
Is someone able to create customised line types? I know that there is the -Tlinea command that allows you to create them because of some cordinates that equal the length of writing and the length of space. however it would serve that within this space there was a tilted line \ the result would be this: - What?
the dash should have l=1mm and space 1mm where in the space halfway there must be a tilted line \ to 45^ l=3mm
If you know how to do it, you can write me the sequence of numbers.
