how to create custom line types
  • Thread starter Thread starter Marco-92
Marco-92
Good morning.
Is someone able to create customised line types? I know that there is the -Tlinea command that allows you to create them because of some cordinates that equal the length of writing and the length of space. however it would serve that within this space there was a tilted line \ the result would be this: - What?
the dash should have l=1mm and space 1mm where in the space halfway there must be a tilted line \ to 45^ l=3mm
If you know how to do it, you can write me the sequence of numbers.
Thanks for the links, I had already looked at that. today I applied again but I couldn't get the type of line you want. I entered the edict notes I copied into glue with the changes that I thought were correct, but without success.
If maybe you would be so kind to show me how the string x the type of line above indicated, you would be very kind.
Hello, I don't understand where I'm wrong. I don't understand how to start the second part after the whole "unknown bitch." I have now changed the data to caxxo but I just can't overlay the second indent to the text. Please help me. Thank you.
I attach the string:
*fecaleignota, unknown fecalele
a,0.5,["fecale ignota",STANDARD,S=4,U=0.0,X=0.2,Y=-0.2],-3
and the image of the result that I do not fit
I would like the shortest hyphens that begin before and after the text, not aboveCattura.webp the text. Thank you.
I arrived at this I would like to get this ----fecale unknown ----fecale unknown------fecale unknown----
I have this string:
a,0.2,["fecale ignota",STANDARD,S=0.1,U=0.0,X=0.1,Y=-0.1],-1.5
What do I have to change?
I'm in tears. .
open the file that contains the line types ( .lin extension) and see how the one with the gas writing is structured
you put comprehensible images because blue on black background you do not read well and hurts the view
