reggio
hi, at the top, in the middle of the 2001 autocad window find place the display of the version "autocad 2001"
and the name of the open deg "disegno.dwg" unfortunately it is extremely transparent and often hard to read it,
I must therefore reduce the window to eliminate transparency and read it decently:
Is it possible to shake it or remove transparency?
Could it be the fault of windows7? in excel for example known the same transparency, but the file name is readable ....
