how to delete old printers/plotters
  • Thread starter Thread starter Sandra_ME30
Sandra_ME30
Reduction 22.12.15 10:51
hi, in the years, in the press selection curtain, I accumulated numerous printers and plotters many of which do not exist anymore,
I tried to delete them with the right button but nothing happens...
Can you tell me how to eliminate them?
mammals 22.12.15 11:38
try the address you find in the expanded voice
sadan 22.12.15 12:39
launches command managementplotter and in the window opening deletes obsolete .pc3 files
hi! I tried with managementplotter and managed to eliminate a good part, but not all,
now I wanted to try with the method of massivonweizen but not .... I remember...
Massivonweizen can you relay? :tongue:
ri-ciao, methods are identical using different roads,
I removed a printer from control panel\hardware and sounds\devices and printers that I had left ... :rolleyes:
and now I only had 2 "default windows system printer" that I deleted
"default windows system printer.pc3" from folders
c:\users\reggio\appdata\roaming\autodesk\autocad 2010\r18.0\ita\plotters
c:\users\reggio\appdata\roaming\autodesk\autocad 2010\r18.0\ita\plotters\file pc3 autocad 2011
It's all clean now!
fats! :
