gil
Sometimes, using autocad I get drawings that contain lines of thickness much greater than standard ones. I attach explanatory image to you.
Note that the “sln” option is therefore disabled the thickness difference, with the above line, was not set in the layers. in the properties I read that it is a polyline but I continue not to understand how to get this effect.
Do you have any suggestions?
gil
Note that the “sln” option is therefore disabled the thickness difference, with the above line, was not set in the layers. in the properties I read that it is a polyline but I continue not to understand how to get this effect.Do you have any suggestions?
gil
