how to make a quota style permanent
  • Thread starter Thread starter Lorenz578
Lorenz578
Good morning.
I tried in a variety of ways, but I can't keep a custom quote style permanent.
clicking on editor styles, any new style I go to create, is not saved and maintained once closed and restarted inventor.
in my case I need to add a new style of quota, which I will go to name and save.
until I remain active in this inventor section, the style is selectable, but when I have to restart inventor, the style disappears.
Can someone please tell me the procedure to keep the new styles permanently saved?
I also had created a new style in norms, not to change the default one, but also in this case it was not kept at the subsequent reopening of inventor.
last (maybe) question: but if I personalize these parameters, they also affect other licenses of my colleagues, or is every inventor customizable according to the user?
and tried to search for this forum too? there are already discussions about this.
I've been writing on this forum for a while and before he writes a new subject, I'm sure it hasn't already been proposed or on the limit I'm re-entry.
There are other similar arguments, but I have found nothing that can help me in what I seek.
Do you have anything else to ask?
or can you give me a solution?
a solution could be to create a special rule to save on the network, and set programs so that they go to take that specific norm. It is clearly a procedure to go up before leaving.
For example, to find it easily, you could call it "norma/nometuo/iso"
Setting is only valid for the car where it is done.
the modified style you save and add to the norm?
Hello stefano.
Thanks for the answer.
the procedure I do (after following guide and other posts here on the forum) is as follows:
- I open any drawing board
- from the management menu, click editor styles
- quota menu, list of various styles, click dx button on one random and select new style
- I apply the changes I need and then save and close
I'm pointing out when I go to quote, if I click on the drop-down menu at the top right (format section) I also get the new style created, but at the next inventor reopening is no longer listed.
idem for standards. I created a new norm as I have already written before, but it disappeared when I opened a new inventor session.
I noticed something. if I click with the button dx on a quota and select new style of altitude, a list appears where the style I created earlier (in this horizontal case) is visible.
so somewhere it is actually saved.
but why doesn't it appear in the drop-down menu anymore?
Bye.
That's what I did! I called her a lorenzo, but then I don't find her at the next inventor's start.
This is the problem I cannot solve unfortunately
If I remember you have to work on the template that goes to get that style.
then on options/files/design dates put the folder on the network, and then set the basic template.
I try.
I don't want to change the default tamplate, or I don't want that once you insert my tamplate into the network and set as a base, it is also for other users.
I have to be sure of this, although as stefano says the modification should be active only on the machine where it is made.
then, if the change should only be done on a machine, leave the template only on that machine and on that installation points locally the folder of styles you will go overwriting (or point it to a second folder of styles on the server)
Okay, I got it.
You don't need to create any new templates, or even less new rules to network.
the procedure described by me is correct in order to create a new style of quota.
The only thing I missed was to save her to make her final.
This didn't happen because I had selected a filter that didn't allow me to see it.
I attach an image to make the procedure more clearstili quota.webptop to right, circled in red, you have to drop the drop down menu and select "all styles"
to this point will appear in the list to left also our new style created (horizontal in my case highlighted in yellow)
dx button on the style and select "Save in style library" (green highlighted)
at this point the style is permanent.
as usual with inventor an endless turn, but we succeeded.
thanks to all for suggestions and advice
lorenz today I tried to make this modification. But obviously I couldn't. (a little like everything I do with inventor, but why should it be so complicated? ? )
the very difficult online guide of inventor is reported that you have to switch from the style settings from the project file by closing first tt the open sessions.. Do you understand? (it is indicated in the second part)
tomorrow I try because today with your procedure I do not know where I was singing but never kept in memory the style created. I find it in the styles management table but never in the drop-down menu. I would like you to propose it to me by default to every new table creation. And if I don't put the big odds 4 or 5 they say they can't see them!
possible that there is no easier and faster way to change the height of quotation texts? a command that in one/two steps allocates to all quotas of that table (which are probably created in x.xxxx) and make it become x.xxx big text or a new quota style created previously?
What version do you have of inventor? I have the 2023 now, I have tried to do the procedure and actually it does not go as it should go.
I have to try again to make some attempts, because since I installed the new version, I haven't looked anymore.
Today I have tried again trying to always follow what the complicated guide of inventor says. (which, however, seems very incomprehensible)
actually worked. all the quotas of that table have adapted to the new text dimension I have indicated.
the caxxata that I did was change only some of the default parameters and not the types of odds that I was using in that specific table so not seeing the differences I was convinced that I sang road. instead under the default object values you have a myriad of types of quotas (from linear quotas to angular ones to those on drilling or welding and many other aspects in the field of quotation and annotation that is pox medificare etc.. all customizable one by one) once customized the default values section object, as the guide says, the change is applied only and exclusively to that table. If the style you want to set it up so that it is saved definitively and then the creation of each table automatically recalls it you need to make saving appearance.
the only thing that then every time you create a table appears a window that reminds you that there is a discord between library styles (just saved) and template style that you are using.
also warns you that it will use the library style.... the problems I think come out as the video said that I linked in the previous message when you update to new version the program or re-direct it that you lose those various settings.
Maybe as the video always suggested and someone before in the disk you need to save the template also.
in fact I think I have the problem, because I have installed the new version.
However, these days, an inventor technician should come and I'll explain some things.
if you leave me general guidelines, place them here
