how to obtain a particular directly from a set
  • Thread starter Thread starter cianolu
cianolu
solidwork software 2009 - creo
good evening boys I ask you kindly if possible this help.
I have been working for a short time and I have no problem getting details directly from the assembly that composes the machine, in essence I am not obliged to design them separated from the axieme and then to carry out the assembly, but everything happens directly on the assembly of the machine under construction.
with solidworks, the thing is more difficult. I tried to build a part, save it, go out and call it back by starting a set; I selected the icon <inserisci componente=""> and then the option <parte nuova="">, then remove the part I care about but I can't work it, that is to treat it as if it were in the single table... I hope it was clear. You know I'm from the old guard, but I have to pull up to 65 so I have no alternative. excuse the unsuitable language</parte></inserisci>
Hi, I don't know if I understand, but I try, maybe he'll fix me. . .
...so, create a new part on a set: This gives it the possibility to exploit all the references of the existing part, finally it has the possibility to save it internally to the assieme or in an external file. (all is done by continuing to display the whole set in transparency), to get out of this mode you have to click on the icon on the top right.
- if however (other situation) needs to change the part of a set within the same must right click on the interested part and choose modifies partI hope I understand and have been of help. .
