What do you mean by projecting, spying?Hello everyone,
I should project this surface in 2d to be able to laser cut.... who helps me since iges files with inventor 2010 can't use them?
Thanks
with inventor does not explain it, it is an imbued piece, not bent.now how ipt I see it but...how to explain it in 2d? so next time I don't break boxes to anyone![]()
Try this if it's okay, bye.the client turned it to me like this, and he can't do better... and I can't give these iges:
I was able to... is the projection on the edge plane, the development for cutting on sheet is anything else.Try this if it's okay, bye.
You're right. I read the request wrong. Then I read the error again.I was able to... is the projection on the edge plane, the development for cutting on sheet is anything else.
to have the cut always perpendicular to the curvature plane... I guess...
a question: but if you leave from a flat plate of plexiglass (so suppose that the piece always has a uniform brush), why would the 5-axis processing not suffice to trim the contours of the piece?
