how to remove the viewcube in autocad 2013
  • Thread starter Thread starter Giovannino60
Giovannino60
in autocad 2013:
1) how do you proceed to remove the bush on the top right for the 3d?
2) What writing is that which appears on the left at the top? How do you take it off?
left click on less in the writings on the top left and take off navigation bar or from command line blackdisplay e digiti 0
instruments>options> ashda 3d modeling> remove the check view window controls
then always in the same place click on viewcube or from command line navvcubedisplay.
in the end it's just about curious. If he clicked a little randomly on those written on the top left, maybe to see if there was a close strike, and he had removed or put a few ticks to see what was going to solve at least one of the two problems alone.
It is not that you are handling an anti-tank mine, a couple of remains do not kill anyone. . .
I have removed the settings to delete viewcube, in options>displays 3d> viewcube, but when reboot autocad recompose, how do you remove it definitively?
