how to set revit layers to export to cad
  • Thread starter Thread starter CAROLINA
CAROLINA
Good morning to all,
I should export a revit project in cad.
you could indicate how to set the layer color that I usually use in revit cad so as to export the design to dwg and be able to print it with the printing pens (ctb) that I usually use.
thanks and a thousand
Hello carolina
when exposing a dwg file from revit is also created the pcp file for printing (it is the old file of pens for autocad 13 and prec.)
in autocad, when you create a new table print styles, there is the appropriate passage in the autocomposition that asks you if you want to convert a pcp.
the alternative is the method "coleman". .
