how to set the exit and return runs of an unscrupulous extractor
  • Thread starter Thread starter beppe296551
beppe296551
Hello, guys, I would like to ask you who knew the arburg, what is the correct setting procedure of a tabled extractor, i.e. how to set the various output and return extraction races for arburg injection presses.
Bye-bye
I press that I do not know the presses you cited
I saw them this year at "parma"
But I can't get the prob.
one thing is the press that serves to support a mold and allows the specific injection
and another thing is the mold's constructive technology
Maybe if you attach a sketch even manual maybe we can identify
and solve the prob
I imagine that a "swinked" extractor should be an external cylinder to the mold equipped perhaps with a piston that synchronized with the openings and closures of the mold do their work
waiting for a match
Thank you very much
hi shiren maybe you can't help me, the question is addressed to operators who know how to mount the molds and specifically on arburg presses, the released extractor is not connected to the expeller table, and I think the forwarding and return runs are set differently by plc of the press. but how?
hi beppe,
if the back of the table is spring and you only have to push it just enter the advance quota, if you are using the selogic series you must first have inserted in the construction of the cycle, "c" key, the icons of the extraction, otherwise do not appear the pages of the parameters: strength, speed and running. with the "?" key to the f942 parameter search for values such as: v603 or f603. if you find them means that the pages are active. If I wasn't clear, tell me the arburg series you're using "h", "hd", "m", "s", "c", "v" and I'll try to be more precise.
Thank you mparini, your answer is more than enough if I have doubts I will let you know
By the way, mparini, I take advantage of your patience, how do I memorize the complete cycle on the floppy, always on arburg? with selogic system?
with the "v" button you access the disk menu. Entering the name you can save it on diskette. before saving it you have to format the disk on the machine. the fine formatting press creates an index file, if you skip this operation you cannot save.
saves, mparini, but if instead of the disk you want to use the hard disk of the press (arburg) to store the different cycles for each article it is possible and how?
