how to switch from imodeldoc2 to iassemblydoc
  • Thread starter Thread starter Mithas
Mithas
Hello everyone,
someone by chance would know how to cast from imodeldoc2 to iassemblydoc in c# for a solidworks application.
below the part that gives me trouble.
private list<node> children(imodeldoc2 comp)
list<node> date2 = new list<node>(c)
iassemblydoc assy = (iassemblydoc)comp; // here should be the cast, but I always have an error
object object</node></node></node>[] comps = assy.getcomponents(true);
foreach (icomponent2 icomp in comps)
if (!icomp.issuppressed())
data2.add(compinfo(imodeldoc2)icomp.getmodeldoc2());
return (list<node>)data2.groupby(x => x.code);
I wanted to be able to pass to the method always modeldoc2 and then convert it into iassemblydoc inside, but nothing comes to mind.. .
♪</node>
I don't think a cast is possible.
However, you can try using the imodeldocextension interface getdependencies method.
I agree with shirokko,
you are getting the imodeldoc2 of the axieme from the component.
and your function would look like
Code:
        private list<string> children(imodeldoc2 comp)
            list<string> data2 = new list<string>();
            modeldocextension extension = comp.extension;
            string</string></string></string>[] namesdependence = extension.getdependencies(true, true, true, true);
for (int i = 0; i < namesdependent.length; i++)
data2.add(new dependences[i]);
return data2;
