hydration sleeve
  • Thread starter Thread starter New Rider
New Rider
Hello everyone.. .
I don't know if this is the right forum bho... I try.. .
the wall-mounted water hose connected to the tap and the spear?
Technically, if it were so, it would be more complex to unroll it. on the internet I found rumors that they say it must be connected, others not. Does anyone have anything on it?
Thank you. .
unless changes of laws and regulations have occurred, the answer is no.
or rather not at the tap, at the spear maybe not, I saw both cases.
If you want/you must have something ready intervention and perfect unwinding you have to go on a naspo rather than on the classic hydrant.
but the naspo is + bulky.
thanks for the attention and excuse for the delay. However, reading here and I have found several opinions. some say yes others do not. I would also like to read in a review of the European standard en 671-3 on the maintenance of water supply and dwarves. Moreover reading in the article cites '' and rewind them in double, possibly well so that they can be properly relocated in the cassettes, reconnecting them to water tap and dispenser launch ''...... so if I read has been approved at the cen..... the norm is operational? I don't think because it should report the word uni en to have value here in Italy. .
ps. (maybe I say a lot of caddy bears patience are young :-) )
After a rapid search I did not find the passage from you reported, but the norms en are standardized at European level.
so yes, it is worth .... also because within the same I found (this yes) the word "annual periodic maintenance: performed, in accordance with the uni en 671-3"
for precision here: http://www.ordingfg.it/download/044.pdfBut I'm puzzled.
