greeswed
Hello everyone,
I propose you a problem and I hope you can help me clarify my ideas.
Suppose you have a double effect hydraulic cylinder with a single stem that supports a certain vertical load. we say that the cylinder is facing with the stem upwards. the two cylinder connections are blocked for example as in my case by two retainers for which the oil cannot flow through the connections. this cylinder under the effect of the load drops (the stem naturally) some mm. the question is as follows:
is it possible that the cause is an internal thread due to the wear of the piston seals?
This topic was a source of debate between me and my colleagues. my answer was no because the volume of oil moved during the descent into the big room, can not be contained in the small room with stem (considering the incomprehensible oil). This problem for me can be seen (I want to correct myself if I'm wrong) in the same way as a cylinder without internal losses with the two connected connections. according to you applying a force down on the stem this goes down? and if we take it from the opposite side what happens?
as often happens from a discussion other arise: someone said that it can not descend because if the gaskets are consumed I have the same pressure in the two rooms and a resulting force would arise that pushes the piston always upwards...
thanks to all
thanks to all
