hypermesh
  • Thread starter Thread starter tonynaruto
tonynaruto
hello to everyone, is there someone who knows a way to align a mesh already made with rivets?
I'll explain better, I'm putting on a plane, but only now my colleague at the cad, has passed the rivets, now I have to make sure that on every rivet, you get a knot of an element, but using the comadi f7 or split, I use too much time, and sometimes I have to remake the mesh...someone knows a fast method to align the mesh already made with the rivets? ? ?
bye,
If you already have the mesh, use the replace command (menu 2d) and then make a smooth.
it would be appropriate to move this discussion in the appropriate section
thank you for the answer, I don't know where the special section is, if I hurt myself...cmq, the replace command you say is f3? If it is f3 cmq after I get many cleanup errors...for smoth, I hope it works....I until now I have tried with f3 f7, shift f6 refine mesh and more...... I will let you know!! !
Good Easter
Solid, could you explain how the smooth command works? after I used replace, with smooth practically cancels the operation made with replace..... .
