hyperworks 11 e windows 8
  • Thread starter Thread starter Michele C.
Michele C.
Good morning.
use hw for a few years. last month I changed operating system, switching to windows 8 and I couldn't install hw 11 that first on windows 7 worked perfectly.
the error occurs at the beginning of the installation, for an incompatibility of the virtual java machine.
have any of you found this mistake and solved it or am I the only madman who went to w8?
Thank you all.
I managed to install it bypassing the installation on win8. I'll explain. incompatibility is not hyperworks itself but the installanywhere program.
then I installed on win7 virtualized hyperworks, then I copied all the files and folders of the program in win8. the program works well, although I think something that doesn't work there is. but for my purposes, that is to create mesh and export it, it works perfectly.
I hope I was useful.
Good evening to all,
thanks for the excellent solution you have found, in fact so you can create any kind of mesh and it all works well.
I created a partition with winxp, not having win7, where I could install hyperworks then copy all files to win8.
My problem is that when I want to start one of the program's solutors (optistruct or radioss) in the cmd window, an error message of the type "impossible to find the specified path".
Has anyone found the same problem?
if there is any solution?
Thank you all!
- - - updated - - - -Good evening to all,
Thank you all!
Does anyone have any tricks to give me to use the hyperworks 12 suite with windows 8? to install it I also carried out the operation exposed to post 2 but I saw that from hypermesh when I have to start hyperview (whose executable I think is hw.exe ) I get an error and not part. Any help?
tomorrow releases version 13 of hyperworks that in addition to supporting windows 8.1, has a number of features added and remarkable performance increases on all solutors (fe-linear, explicit, cfd, mbd, systems).
bye
